The use of visual display to relay information to employees and guide their actions. The workplace is usually set up with signs, labels, color-coded marking etc..., so that anyone unfamiliar with the assets or the process can readily identify what is going on, understand the process, know what's being done correctly and what is out of place.
Tip excerpted from: The Professional's Guide To Maintenance And Reliability
