How Do You Know Whether Moisture Is in the Atmosphere or in Your Head Space?
There is only one simple way to determine this and it is with the use of a standpipe in your breathers. Breathers without a standpipe will always expire from the bottom first regardless of where the moisture is coming from. Breathers with a standpipe will expire from the top first if there is moisture in the headspace and from the bottom first if there is moisture in the atmosphere.
Learn More
Tip Provided by Mark Barnes, VP, Reliability Services
