In the past decade the filter cart has gone from being a specialty item to being a standard lubrication tool for maintenance professionals. As organizations place more and more emphasis on precision lubrication and contamination control, they have come to realize just how valuable these systems can be. However, there are a lot of common mistakes made when it comes to selecting portable filtration units and a lack of knowledge of these issues can prove costly. By carefully considering the following items, you will be able to avoid these costly mistakes and obtain maximum value from your filter cart purchase.
To read the rest of How to Select a Filter Cart for Maximum Value, visit: http://descase.com/splash/rwmt1010
Tip provided by: Jarrod Potteiger, Product and Educational Services Manager
Des-Case
Tel: +1 615.672.8800
Des-Case Logo
