Bad procedures lead to bearings routinely receiving more grease than they’re designed to handle. The excess ends up being pushed into the motor casing or purged onto the floor. Over lubrication happens when re-greasing intervals are scheduled based on time instead of condition. Control lubrication tasks with ultrasound to monitor condition and maintain optimal friction. The time between greasing intervals increases, resulting in less grease used per bearing.
Learn more >
Tip provided by
