I have a simple tip that always saves me time. When making measurements, place a piece of white electrical tap on the side of the tape measurer, each time you take a measurement write it down on the white tape then transfer to your plan or drawing when done.
Reader Tip provided by Scott Foster, Maintenance Mechanic, St. Joseph Medical Center, Everson Washington
Thanks Scott - your Reliabilityweb.com Elements T Shirt is on the way!
Do you want your own Reliabilityweb.com Elements T Shirt? Send in a Maintenance Tip here
