A strong Mechanical Integrity solution will identify fixed asset corrosion and containment threats and prioritize risk mitigation based on failure probabilities and consequence. A compliance-code-driven approach provides engineers with comprehensive visibility over critical degradation mechanisms, bad actors and performance indicators, aligning people and API 580-compliant processes to drive increased uptime and cost-efficient asset utilization.
This webinar will demonstrate how semi-quantitative MI risk analysis drives prioritized, cost-justified strategies to improve safety, asset utilization and financial return within an APM program.
Learning Point Takeaways:
1) Optimize profitability
2) Reduce OPEX / CAPEX
3) Optimize maintenance spend and avoid unplanned expense
