Normally, these modifications will not require a lot of time or expense and many can actually be performed while the equipment is in operation. In the beginning, it is important to identify the appropriate modifications for different classes of equipment based on criticality and the potential value of deploying advanced lubrication techniques.
  1. How to modify lubricated equipment for oil sampling and inspections
  2. How to modify equipment for contamination control and lubricant application
  3. How to select lubrication accessories
