Quantitative current data allows localization of ground. To perform these tests obtain a test signal from a power source and insert an ammeter between source and probe. Provide a return lead to the source from the motor frame.
In Figure 6-25, connecting the probe to point “A,” which is closest to the grounded coil will provide a higher current flow then when connected to Points “B” or “C.”
Figure 6-25 - Localizing Ground with Ammeter
It is harder to localize grounds in delta configured windings because current differences aren’t as great due to multiple flow paths.
Keep reading...Show less
Reliability.AITM
Start
Quick Time to Value: How to Accelerate ROI in EAM Implementation
Enterprise asset management (EAM) implementation is sometimes misperceived as a complex, resource-intensive endeavor. But that perception is rooted in legacy approaches and outdated systems.
Optimize Operations in 7 Steps: The Strategic Art of Maintenance Planning and Scheduling
Effective maintenance planning and scheduling are essential to prevent unplanned asset failures from dictating your schedules and driving your budgets. In a reactive, unplanned environment, maintenance efforts falter—funds meant for proactive upkeep are instead wasted on waiting for parts, delayed equipment transfers, and emergency fixes that disrupt planned work
Case Study: How Waites Cemented $1 Million in Savings by Eliminating Unplanned Downtime for Buzzi Unicem USA
Minimizing downtime in the cement manufacturing industry is crucial, as each minute of operational delay can lead to significant financial repercussions.
Laying the Groundwork: The Role of Naming Conventions in Spare Parts Management Success
This article outlines best practices for overcoming these hurdles and highlights the foundational elements of a successful spare parts management approach.
Industry 5.0 Is Empowering Today’s Factory Workers and It’s a Long Overdue Revolution
The impacts of Industry 4.0 and its younger sibling, Industry 5.0, fall right down to today’s factory workers. While embedded automation and optimization within the Internet of Things (IoT) and Industry 4.0 have the power to drive new efficiencies, they have also led to the introduction of more complex job roles and tasks, but for fewer frontline workers.
From Data to Action: The Complex Path of Advanced Analytics and Reliability in Industry
In today's industrial landscape, the buzz around advanced analytics is hard to ignore. Companies are increasingly looking to harness the power of data to drive efficiency, reduce downtime, and gain a competitive edge. However, the journey from collecting data to taking actionable steps based on that data is far from straightforward.
Engaging and Retaining the Asset Management Workforce
Employee engagement and retention are critical for the success of asset management organizations. High turnover rates and labor shortages pose significant challenges, impacting operational efficiency, safety and overall workforce morale.
Do or Do Not
Data analysis is critical to understanding problems and decision-making. Analysis that is not followed up by an action is likely a wasted opportunity, but not always.
Achieving Trouble Free Bearing Life Through Defect Elimination
When a machine is designed, one of the major considerations the engineer must make is the selection of proper rolling element bearings. Some of the factors to consider in selecting bearings are shaft speeds, loads (both axial and radial), the environment they will run in, how to relube them, the duty cycle, etc.
Who Does This Belong To?
In today’s fast-paced connected world, you and your organization create an abundance of data. In the past, large corporations with multiple locations relied on in person site visits or information provided by the on-site team for updates to productivity in facilities. But what if there was a way to do this remotely?
Upcoming Events
MaximoWorld 2025
August 4 - 7, 2025
View all Events
ChatGPT with
ReliabilityWeb:
Find Your Answers Fast
Start
